Lokar or Bouchillon? #1004870
06/01/11 11:13 PM
06/01/11 11:13 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
I need a kick down cable set up for my 340/727 a-body conversion. The engine has a Holley 750. I don't have any experience with this product or either of these company's so I'm looking for any advice/experience that will help with my decision, thanks.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Lokar or Bouchillon? [Re: busboy] #1004871
06/01/11 11:49 PM
06/01/11 11:49 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
A lot of people rave about the Bouchillon. My local speed shop had the Lokar. It was easy to install, took maybe 20 minutes, and works great. I used it initially on a crossram hemi and it was easy. Hope this helps.
Re: Lokar or Bouchillon? [Re: busboy] #1004872
06/01/11 11:49 PM
06/01/11 11:49 PM
Medford OR
FrankenScamp Offline
Medford OR
I have the Lokar setup....it works just fine when properly adjusted.
I've heard all over "the Bouchillon is a better product". Never bought one....never needed to replace the Lokar.
Re: Lokar or Bouchillon? [Re: FrankenScamp] #1004873
06/02/11 12:07 AM
06/02/11 12:07 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I bought a used truck that had a Lokar throttle cable. The inner wire had worn thru the outer sleeve and was binding up the throttle. I changed it out with an OEM cable.
Depending on the carb you use, the throttle end needs to be installed so it has the correct carb to trans lever ratio for best performance. Bouchillon gives you options, Lokar doesn't.
So when I needed a kickdown cable for a '68 Valiant, I didn't buy a Lokar.
Re: Lokar or Bouchillon? [Re: busboy] #1004874
06/02/11 12:10 AM
06/02/11 12:10 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
bouchillon
i have it on a 440/727, the customer service at bouchillon is awsome, you can actually talk with the owner and inventer Randy Bouchillon, he walk me threw some questions i had, working great
Re: Lokar or Bouchillon? [Re: cornet684me] #1004875
06/02/11 12:13 AM
06/02/11 12:13 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
bouchillon
bought AC stuff from Bouchillon,
JR has got on the phone with me, seemed like a good guy who knew his stuff. I have a Lokar on one of my cars, next one will come from Bouchillon.
Re: Lokar or Bouchillon? [Re: FrankenScamp] #1004876
06/02/11 12:31 AM
06/02/11 12:31 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Same here
Re: Lokar or Bouchillon? [Re: WILD BILL] #1004877
06/02/11 12:45 AM
06/02/11 12:45 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Another vote for the bouchillon kit.
Re: Lokar or Bouchillon? [Re: Pat_Whalen] #1004878
06/02/11 01:52 AM
06/02/11 01:52 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'm using a Bouchillon because it works well & they're throttle cable bracket will allow me to use my cruise on my RC.
Re: Lokar or Bouchillon? [Re: BulletBob] #1004879
06/02/11 03:35 AM
06/02/11 03:35 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Seems like a pretty even split here. I've seen both work well. I went with Bouchillon though. 8 years and still working great.
Re: Lokar or Bouchillon? [Re: Kern Dog] #1004880
06/02/11 07:39 AM
06/02/11 07:39 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i have been using lokar kickdowns for years now and have never had any issues.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Lokar or Bouchillon? [Re: abodyjoe] #1004881
06/02/11 12:18 PM
06/02/11 12:18 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Lokar here also.
Re: Lokar or Bouchillon? [Re: stumpy] #1004882
06/02/11 12:26 PM
06/02/11 12:26 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Lokar here. Works just fine and looks clean.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Lokar or Bouchillon? [Re: Junky] #1004883
06/02/11 12:37 PM
06/02/11 12:37 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I have the Bouchillon piece on my Mirada.
I like it, good customer service too from those guys.
Re: Lokar or Bouchillon? [Re: 440newport] #1004884
06/02/11 01:46 PM
06/02/11 01:46 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I was skeptical about the Bouchillon it because I wasn't exactly hooking it up to a conventional setup. I'll be honest. when I opened the box I saw a nightmare but when I read the instruction, they were so clear and concise, you just couldn't go wrong.
I had the Lokar setup years ago on my 70 Dart, Slant 6 / 904 and it was the universal kit. I had to make alot of bracketry to make it work right on the carburetor end. The trans was just a screw and a snap, the only thing is, it looked hokey.
The BP kit was a fantastic upgrade to my stock throttle and kickdown linkage (I got both kits that work off one another) FWIW, I hooked up the kit to a Dual Quad Eddy Manifold with Twin Edelbrock carbs.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Lokar or Bouchillon? [Re: Pyper70] #1004885
06/02/11 03:22 PM
06/02/11 03:22 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Bouchillon...most trans guys will tell you the same. I have ued them and have reccomended them to several friends who are all very happy with them. Only thinh Locar has over Bouchillon is bling
Re: Lokar or Bouchillon? [Re: GTXKen] #1004886
06/02/11 07:39 PM
06/02/11 07:39 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have a new Lokar kit that I've had for years. When I put my CrewCab together I passed on it & built my own using Chrysler parts & guidance from John Kunkel It worked flawlessly for almost 5 years until the trans finally quit at 200k. I would've had just as much fab work to use the Lokar on my combo.
Re: Lokar or Bouchillon? [Re: busboy] #1004887
06/02/11 09:40 PM
06/02/11 09:40 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Bouchillon here. Engineered to work on Mopars right out of the box - no fuss. Not as pretty as a Lokar. I seem to recall that the cables themselves are OEM pieces intended for trucks with A518's.
Re: Lokar or Bouchillon? [Re: 70Duster440] #1004888
06/03/11 12:22 AM
06/03/11 12:22 AM
busboy Offline OP
busboy  Offline OP
Thanks all for the reply's, seems like I've got to flip a coin now, seems like either one would work fine. I do appreciate a company with good customer support and since this is hidden under the air cleaner anyway I gotta say I'm leaning towards the BP piece. Thanks for all the replys
Re: Lokar or Bouchillon? [Re: FrankenScamp] #1004889
06/03/11 12:29 AM
06/03/11 12:29 AM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
i use the lokar on my cars,works great.i also work at lokar and can tell you its a quality piece and 100% made in the USA....knoxville,tn as a matter of fact and lokar has a lifetime warranty on their products.either way,you cant go wrong with either
