Re: sb intakes
[Re: fowl play]
#1004562
06/01/11 06:08 PM
06/01/11 06:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran a M1 with a dom adapter on my W-2... it runs better with the Indy W-2 with the adapter (that was the big runner M1)... but I think I changed a few things at the same time so I cant say for fact what was better
Re: sb intakes
[Re: fowl play]
#1004563
06/01/11 08:08 PM
06/01/11 08:08 PM
Posts: 7,506 Az
Crizila
Az
I am going to try a 1" open spacer under my existing 1" 4 hole Wilson spacer on my Victor 340 this Friday night just for ( 408 motor ).
Fastest 300
Re: sb intakes
[Re: Dunnuck Racing]
#1004567
06/01/11 09:08 PM
06/01/11 09:08 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
it looks like maybe the booster signal went down on the victor manifold and it went lean due to it loosing 10-15lbs of fuel with teh super as compared to the plain victor,, if you had just richened it up it would prob have picked the tq back up and made more hp,,
you can just take a calculator and aveage every 1000rpm,, then compare those numbers to see gains,, thats what i do but my dyno does it automatically through the range i select,, you can also look at average fuel comsumption numbers to see if they go up or down with manifold changes/carb changes,, etc..
to me after looking at your test,, id still say super victor all teh way
Re: sb intakes
[Re: fowl play]
#1004568
06/01/11 10:40 PM
06/01/11 10:40 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
i have a 414 inch small block, race only dart.high compression 620 lift cam. it has a torker 340 intake with 950 hp holley. koffel's place said when they built it the torker made more hp., but i thought while i was doing some things i would try another one. i have a one inch spaceron the torker. any real life experiance gong to a mopar m1 with a 2 inch spacer. thanks for any info.
on my 398 w2 small block with a 1000cfm i went from victor to indy and indy was about .08 quicker
