Page 1 of 3 1 2 3
Idle Stop Solenoids #1003716
05/31/11 02:52 PM
05/31/11 02:52 PM
Ohio
RestoreCuda Offline OP
Ohio
Are Hemi and Six Pack idle stop solenoids the same, in 1970? If so can anyone help with a part number?
Re: Idle Stop Solenoids [Re: RestoreCuda] #1003717
05/31/11 03:26 PM
05/31/11 03:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Here is one i just picked up for my 71 340, i think 70 is the same for Hemi and 6 BBL #DR1114429 . Good Luck!! took me a few years to find one.
Re: Idle Stop Solenoids [Re: ademon] #1003718
05/31/11 04:01 PM
05/31/11 04:01 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, DR1114429 is the correct number for 1970&71 Hemi, and 440 Six Pack.... and 1971 340 engines......Which of course means that us lowly 71 340 owners need to fight it out with the Hemi guys when it comes time to buy one (not usually a cheap adventure!).
*I can restore most of them to look new again, even one as crusty as shown above, some minor pitting may show afterwards if the core is corroded badly
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003719
05/31/11 04:05 PM
05/31/11 04:05 PM
Ohio
Ohio
Thanks I appreciate it.
Re: Idle Stop Solenoids [Re: RestoreCuda] #1003720
05/31/11 10:14 PM
05/31/11 10:14 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Whats the going rate for one of those solenoids in nice shape? $120 or so?
Since I'm one of those lowly 340 guys looking to buy one..
Re: Idle Stop Solenoids [Re: NV69B7RR] #1003721
05/31/11 10:26 PM
05/31/11 10:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I restored 3 used ones I had in the past month, all went for between $375.00-$500.00 based on condition (resto service cost is $75.00, or free with a carb restoration). I've personally paid over $600.00 for an NOS one in mint shape and know another buyer who bought 3 NOS ones recently (each with a fair amount of whitish corrosion on the silver case) who paid over $1000.00 for the lot. So yes, these suckers can get expensive!
In my experience you luck out and find one cheap in a parts lot or a swap meet from an unknowledgable seller or you pay full market value once it's been id'd and hits the open market. Not many land in the middle.
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003722
05/31/11 11:02 PM
05/31/11 11:02 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Can someone explain the function of the idle stops?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003723
05/31/11 11:25 PM
05/31/11 11:25 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Scott did an excellent job on my solenoid, and by the way Scott, looking at your post you still owe me a future rebuild on a solenoid since you restored the pair of hemi carbs for my convertible. One carb rebuild equals one free solenoid rebuild right ?? Just a joke. I believe I have a few solenoids left over..
logan426
Re: Idle Stop Solenoids [Re: MLR426] #1003724
05/31/11 11:40 PM
05/31/11 11:40 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
If you're gonna play, you gotta pay....
Thanks for the answer!
Re: Idle Stop Solenoids [Re: NV69B7RR] #1003725
05/31/11 11:47 PM
05/31/11 11:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, that assumption is correct, even past customers qualify, one solenoid per application is on the house.
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003726
06/01/11 12:02 AM
06/01/11 12:02 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Oh now you re-word and say by application uh !!
Multiple carbs don't count now.. Just screwin with you Scott, and by the way I'm always a current customer as I never left you to seek services else where because you never gave me a reason too.
logan426
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003727
06/01/11 12:03 AM
06/01/11 12:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a step by step of a typical restoration, aside from plating most can do these themselves if you are careful. This unit is not a DR1114429 but the process is exactly the same.
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003728
06/01/11 12:04 AM
06/01/11 12:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003729
06/01/11 12:04 AM
06/01/11 12:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003730
06/01/11 12:05 AM
06/01/11 12:05 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003731
06/01/11 12:05 AM
06/01/11 12:05 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
5, See that copper wire? It's VERY delicate, DON'T break it!
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003732
06/01/11 12:06 AM
06/01/11 12:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
6 Be careful with the washer, the end of the copper wire is attached to it and nothing else holds it in place on the end of the coil, put the entire assembly, including the washer left in place as shown here, in a safe place for reassembly later.
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003733
06/01/11 12:06 AM
06/01/11 12:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003734
06/01/11 12:07 AM
06/01/11 12:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
8, The brass plunger is cleaned in a citrus based cleaner and the case is polished to bare metal on a wheel before being sent out for plating
Re: Idle Stop Solenoids [Re: ScottSmith_Harms] #1003735
06/01/11 12:07 AM
06/01/11 12:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
9, the plunger is then hand polished with Wenol to a shine, rubber is cleaned with solvent and dressed with a non shiney rubber protectant
Page 1 of 3 1 2 3
