Re: Turbo size? Opinions welcome.
[Re: ADakotaRTGuy]
#1001471
05/28/11 09:20 PM
05/28/11 09:20 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You need something bigger than a T4 flange if you plan on a single. If not, you're going to seriously limit yourself on power and have insane back pressure.
[Re: ADakotaRTGuy]
#1001476
05/29/11 12:30 PM
05/29/11 12:30 PM
feets
Senior Management
Senior Management
Irving, TX
The twins vs single debate will continue until the end of time. What it boils down to is packaging. You should use whatever will fit in your engine compartment best.
[Re: ADakotaRTGuy]
#1001479
05/29/11 01:55 PM
05/29/11 01:55 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
You can remote mount it! Somewhere under the bed!! Alot more pipe involved but no worries about where to mount it!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: EV2DEMON]
#1001487
05/29/11 06:11 PM
05/29/11 06:11 PM
Posts: 142 Maryland
Sick 660r
Maryland
Im dumping mine out the fender under the antenna. I will only see a few street miles so im not that worried about it.
2000 dakota
418 magnum
paxton novi 2k
T56
