What Seam Sealers? #1000796
05/27/11 01:52 PM
05/27/11 01:52 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I am replacing a lot of panels on my cuda, including the firewall. I would like to know what are the best/proper-application sealers to put 'between' the panels, (as they are being assembled) and also what to apply over the inside gap once the panels are welded together.
I've seen that the original stuff that oozed out from between panels has a somewhat porous look, like some kind of expanding sealer.
A local supply guy suggests 3m 8505, but I'm not convinced that will meet all the different requirements.
What say you all?
Thanks very much.
Clay
Re: What Seam Sealers? [Re: lahatte] #1000797
05/28/11 10:46 AM
05/28/11 10:46 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
The 3M 8505 will dry hard and crack. DAMHIK
Re: What Seam Sealers? [Re: lahatte] #1000798
05/28/11 12:29 PM
05/28/11 12:29 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Contact RestoRick on the board here.
restoemail@gmail.com
Ray
Re: What Seam Sealers? [Re: lahatte] #1000799
05/28/11 02:35 PM
05/28/11 02:35 PM
SeventySatellite Offline
Do not use that 3M 8505 Fast n Firm stuff for seam sealing. I just spent alot of time removing it from my car because it dried hard and cracked. Read my previous post for other options.
Re: What Seam Sealers? [Re: lahatte] #1000800
05/28/11 02:50 PM
05/28/11 02:50 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
A good friend of mine is a professional body shop man and he recommended a product made by Lord Fuser available at some NAPA stores. It's not cheap, [ $15.00 a tube ] but this stuff works. If you get it on your hands get it off quick or it will have to wear off.
Re: What Seam Sealers? [Re: SeventySatellite] #1000801
05/28/11 05:22 PM
05/28/11 05:22 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Thanks for the responses.
Regarding the 8505, did you use it as out of the tube, or did you apply some thinner to it to smooth it?
Thanks.
Re: What Seam Sealers? [Re: lahatte] #1000802
05/28/11 05:31 PM
05/28/11 05:31 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Like already mentioned, do not use the 3M fast and firm if you want to put it on thick and sloppy like the factory, it shrinks and cracks a lot when it dries.
Re: What Seam Sealers? [Re: hemi70se] #1000803
05/28/11 07:36 PM
05/28/11 07:36 PM
maine
LO23 Offline
LO23  Offline
maine
3m automotive mmm8361-
takes a foil cartride gun and pricey but works great
Re: What Seam Sealers? [Re: LO23] #1000804
05/28/11 07:43 PM
05/28/11 07:43 PM
MO
cdp Offline
cdp  Offline
MO
Wurth Brushable will never crack and goes on extremely smooth. Dries fast.
In a toob, try Crest Qwik Seam. It also dries fast and hard.
Both are very high quality products and none of them have ever cracked on me like....3m.
http://www.crestauto.com/products/Crest%20Mich%20E-Cat%20v1.5/HTMLCAT/Catalog47.htm
http://www.pelicanparts.com/catalog/shopcart/GADG/POR_GADG_WUGARG_pg17.htm
Re: What Seam Sealers? [Re: LO23] #1000805
05/28/11 11:49 PM
05/28/11 11:49 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
What's that front end setup? What kind of cost for something like that?
Re: What Seam Sealers? [Re: lahatte] #1000806
05/29/11 09:36 AM
05/29/11 09:36 AM
maine
LO23 Offline
LO23  Offline
maine
its a control freak system,got the front and rear set up for AMC.was around 6000.00.its a 68 rebel sst convertible.
freakride dot com
