Quote: Remove the radiator cap and let it warm up. You should see a LOT of water moving through the radiator when the thermostat opens. If you don't see much water moving, it's likely your stat isn't opening.
DAMHIK
I'll give this a try at lunch time! Thanks for the idea.
