Move the bracket to the front, and line up the holes as colored:
this bracket wont flip around and bolt up,it has 4 holes,the alt pivot hole is offset from the 2 holes that are right together,the 4th hole is for the a/c comp bolt
D'oh Thanks for the additional clarification
If you ever find yourself in a fair fight, your tactics suck.
