If you can get a wiring schematic just find the right color feed to that front circuit and test it at the switch for 12 volts coming out of it with the key on and turn signal on. If it has no power like that it is the switch since the other lights work and share the same feed. Ron
I already told the colors on my first reply TAN one side and LIGHT GREEN the other side
Then test the one to the side your problem is on. It will tell you alot as to where the problem is.
Usually when I have a ground problem in a front lite many times it will light the turn signal indicator on the dash when you put the park or headlites on as it will backfeed thru that circuit looking for a ground. Ron
