Quote: Thanks for the input. On my other car with a Holly carb, it's no problem to fill the bowl through the vent with a little funnel. On the Carter (Eddy) carbs, there is no place to do that without pulling the top of the carb off.
I use a contact lens solution bottle to fill the vent tube on the primary side. Works good, though I can't say how it is on an edelbrock.
