On a cold start up with Eddy carbs and the fuel evaporation problems they have, my question is; Is it better to use starting fluid to get an immediate and rapid engine start or to crank the starter to pull fuel into the carbs resulting in alot of low RPM cranking/slower start? The concern is oil pressure, cam/lifter wear and general engine wear.
