Quote: Width and backspacing for 17 inch rims would be the same as for any other size of rim. If you have a 14 inch rim that fits properly then just order 17 inch rims with the same width and backspacing and your tires will be in the same location.
Yep but you probably want to go wider as 14" wheels were very narrow. Should be able to get away with standard back space. As far as how they look that is a question only you can answer for yourself as opinions are like butt-wholes every one has one and they all stink
