I'd always use a plate, and same fasteners, same thread engagement, same lube, etc.. Torque plate valve jobs have been around too since the 70's that I know of.
I know most of you might only get excited about air flow numbers, but all the air flow in the world won't make power, if it doesn't stay in the cylinder to work for you.
