with a race only vehicle I cut a small slice out of the gasket on the radiator cap. this effectively eliminates any pressure in the cooling system. ever see a car blow a rad hose in the lights? ever see a engine block have the freeze plugs pop out from a combination of stress from the stock engine mounting points and a small amount of cooling system pressure? this eliminates that possibility
