Update: I removed the filter and turned the pump clockwise. No oil was produced. I tried back priming from the oil filter and tried priming with no result. If it helps, the priming rod has about 5-6 inches of bubbly oil on it when I am done.
I don't even have 1/2 lift, but the other 1/2 is nitroused.
