checking out an 8 3/4 axle with a limited-slip and after pulling the axles i couldn't re-install the drivers side all the way. after closer inspection i found the inner set of clutch plates moved to where they are not aligned with the outer set. i tried to move them with no luck. any ideas on getting them back in alignment? thanks, dave
