lay the crank in it's side and make a magic marker mark @ 12 o'clock on a main journal and on an adjacent rod throw then measure the (offset) distance between the two. that's the "throw" distance and double that for the stroke ie an offset distance of 2&1/8 would b a 4.25" stroker
