If the new stroker is for your 72 rr, I would recommend the Weiand 8007 action-plus. It's a great intake AND fits a thermoquad if you want a factory appearance. Only negitive is: the action-plus does not have the factory style mounting boss for the coil. I used a bracket I found and mounted it similar to the 340 6-packs.
