I can't tell if its the brake light or running lights by brighness. Sorry I wan't clear in orginal post here is a better rundown:
With all fuses in:
Their is a drain when car is cut off
With ignition on or engine running the tail or brake lights are always on (they don't get brighter when you depress the brake but can tell if it is brake or running lights)
With fuse marked "tail"/"stopr"(?) pulled:
All of above except no drain on battery
The white wire is wraped tightly in electrical tape after it leaves altenator and after it leaves brake light switch.
Their are 4 wires to rear lights. It looks like dark green and dark blue go to driver side and a black and dark brown to passenger side. The black wire is cut. Their appears to be a black wire running from the center bulb of each light panel.
Both turn signals work, the rear lights are always on but they flash darker.
Thanks everyone for the comments so far.
