Looking at the first and second dyno sheets it looks like you lean it down, which it seems the motor really liked What happened to the AFR readings on the 2nd sheet
I knew what the A/F ratio was from the previous tests and left the air turbine off for the last BONZAI pull. I do wish I had that data though-thanks for reminding me. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
