Depends on cam lift and usage. The OEM style rocker gear has high side loads, and can be a pain to get oiling to the tips of the push rods. I generally have to replace the titanium lash caps each year. The guys running the Barton set-ups run more lift and rpm than I do with few issues. My cam is .780" lift with lots of spring pressure and I street it. If my heads could run them, I would.Stage V is really good, but I think the benifits from the newer design becomes a must at a certain point.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
