It's a 4 quart pan one that's on a '71 383. I run a windage tray. With new oil filter I run 5 quarts of oil.
I would be a little concerned about pumping all the oil outa'-da'-pan. If I were you ...I would look-into buying a larger capacity pan.
FOR NOW ... make sure you DO get the oil nice-and-warm before you take-it up-to 6,000 rpm.
