Pressures are fine.
what Stump said, You're good
But it is low and you might want to know why.
Why do you think that's low. Unless it's a brand new no mile motor those pressures are fairly normal if that is an in gear at idle 20psi. My 408 runs about 60psi at 6500 and 20psi in gear at idle(750 rpm}. After racing it for 2 years at those pressures I still show very little bearing wear.
