99 durango, A500.. customer droped off his truck.. it does not want to shift to 2nd.. not till RPMs are up.. TV cable looks fine.. no codes either.. the truck doesnt idle well and stalls.. Can the TPS cause this trans problem? also can low oil psi cause this? trans fluid looks good..
Please let me know what you all think.. oh when it does shift it doens slip..
thanks
