Need more info before making any recommendations...
Does the 8 3/4 have large bolt pattern axles , if so are they new axles with the big car brake offset or redrilled small bolt pattern axles ?
As far as the driveshaft , if the 8.75 is longer than the 8.25 how can anyone say it's onk to to use a draveshaft that is obviously too long ?
