Reduces intake piston to valve clearance (intake is further open around TDC, closes intake valve sooner after BDC building more compression pressure. Street wise mentioned the Crower 271HDP cam, that is what I have in the 383. If you were going to buy a new intake, the Performer RPM would be a good choice.
