Are you using the main studs and bolts that came with that world block??? Before you build it, there is a thread on here about those studs/nuts you should read. I would get a set from ARP just to be safe.
That would be this thread. https://board.moparts.org/ubbthreads/show...0&fpart=all
My World Hemi block is at the engine builder right now. Dan Smith, Qwkmopardan on here.
It had the no name studs in it, I'll never understand why they installed no name studs but used ARP nuts. The studs were replaced before the line bore was checked. It was a little tight and had to be opened up, or so I was told.
![](http://richdetert.com/Hemi%20004.JPG)
Kayse can't keep up at all now. lol
