ok, well I pulled the block out of the box, new world block, and put it up on the stand. Found lots of casting flash in the upper water pump holes and one of the coolant passages at the rear of the block. I am expecting some but the passenger side water pump hole was amost closed off. Then I put a piston in the bore to see if it fit, it almost fell through. What should I have for bore clearnace? Block p# P5153862 and pistons are P4876327 and what rings should i get, mopar doesn't carry the recommended ones anymore.
Tim
