I need to remove glass from a 73 Roadrunner - I bought the tool withe the 90 degree blade and cable/handle ----- any tips before we start ?
That tool you have is perfect IF the windshield is already cracked and needs to be replaced..If you want to reuse the glass used the wire method and make sure the edges are heated well enough to glide the wire thru with no hang ups...good luck... The 90* tool is fine but if you lean it to one side or the other just even a little you will hear a sound that you dont want to and your neighbors will not like the language...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
