It is tough. Since they are basiclly glued in (butyl), so going to a pro maybe the way to go. Although you can get a new one installed for aprox $250.00 (sometimes alot less), so there is a savings to get it out yourself. Alot of them ending up cracking when you try to remove (even by pros), so good luck.
Have you done it??
If not how can you give advise?
The brass wire I have shown above is a very easy way to get them out without any risk of cracking them. I have cut out 5 of them so far by myself and have not even come close to breaking any glass. Once you cut 360 degrees around the windshield, it can be lifted out very easy, at least on E bodys.
