Hard to tell from your pics - can't see the machining marks. Anytime I see goofy, double, triple, jittery hits like that I tend to believe it was factory. Saw a Hemi engine hit a few times between the pad and the core plug!
Again - need to see if the pad is flat and still has the proper machining marks.
