I had a question for some of you fellow racers.I am a sportsman footbrake racer.I am presently running a Pro Systems 4150 carb.Sheet on carb shows to flow 944cfm.I have a 1966 Dodge Coronet with a 512 lowdeck.I was interested in trying a Holley 1050 Dominator.A friend of mine that builds engines recommended the list #8896.Another friend told me #9375.Which would yall recommend?The car weighs 3530lbs. with driver full of fuel.In cool weather the car runs 6.20's eighth mile.Would I see much E.T. gain for the $700.00 plus dollars carb price?Indy 295 cnc EZ's (flow 350In.245ex.)Indy 4150 single plane.650 CompCam solid flat tappet.13.5 to 1.Thanks for any advice.
Booney.....we would look for at least 2 tenths pickup in the 1/4 on your 512....there's no doubt it will run stronger up top but the trick is to not loose any down low....Jesse
