Bill, I think I would go with a plate. Wasn't sure if I wanted to do one on my car or not. Now I don't think I would want it any other way. You can cut off the stock mounts for clearance and are not so limited how you have to run the lines. It is also much easier to install the motor by yourself. Just my opinion, but I really don't see a reason not to. Either way, good luck this year. Hope you can finally get to have some fun!
Randy
