Re: Slant 6 manual steering box same as a V8's?
[Re: mcmopars]
#882205
12/20/10 10:19 PM
12/20/10 10:19 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
do many of the bushed boxes go bad?is there that much of a differance to be concerned about on a street car?
I'd say no. As long as the box is clean (internally), lubed, and adjusted properly you won't know the difference. Except for the 20:1 worm gear, there aren't any new parts available for these except for bushings, bearings and gaskets. A rebuild is basically a good cleaning, assembly, and adjustment to specs. You can do this at home but the cleaning can be tough if the grease is dried out (common). FWIW, I have a '74 Dart Sport 225 car and the gear box has the 'V8 bearing lump' on it and the box that came with my 318 '68 Barracuda doesn't have the lump. I don't think they had a different die casting for gears that would get a bearing, it was just machined differently. You can ream out a bushed housing and install a bearing if you want.
