See the rib that is behind the fill hole that goes a little less than half way back. That is with the bearings. If that rib is not there it's a bushing and you don't want that one. Stick with the bearing type.
I don't believe that at all. The bushing or bearing is at the other end of the case, at the sector output. Why would that little lump have any connection?
I'm checking out mine tomorrow. Have some from V8's, 6's, A, B and E's I thought A-bodies got the bushed ones and B/E got the bearing ones. ![](/ubbthreads/images/graemlins/shruggy.gif)
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
