See the rib that is behind the fill hole that goes a little less than half way back. That is with the bearings. If that rib is not there it's a bushing and you don't want that one. Stick with the bearing type.
I don't believe that at all. The bushing or bearing is at the other end of the case, at the sector output. Why would that little lump have any connection?
It shows it has the bearings. The ones with bushings don't have that hump.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
