I remember a thread where guys were discussing epoxy, aluminum foil, steel wool, who knows what else, on blocking the crossover.
I wish I could remember who said it, but it was along the lines of
'if you're gonna pack a bunch of stuff down in the crossover port, make sure to put $100 bills in there too, then when it breaks loose and gets down in a cylinder at least you'll have the $$ on-hand to fix it'...
I got feed up ordeing valley pans and getting the wrong one localy the crossover port is hour glass shaped so the epxoy can not fall in and last I checked my exhaust pushes gasses out never sucks in
But if it does fail I promise you guys will be the first to know
I would think that if the heat rised is operating properly it's going to PUSH the gases from the restricted passenger side to the unrestricted drivers side .
