I don`t understand why more people are not having issues with mounting "true" 15x7 trim rings on Wheel Vintiques 15x7 rallyes. The front offset is wrong.. stock BS is 4.25 which it is ..But the rim is actually narrower now. By time the trim rim is nearing the catch area, the edge of the trim ring hits the center portion and therefore won`t let the ring fully seat .I sent two back to Summit and gave up !!
