After measuring my Driveline angle at 1 degree down, I modified the transmission crossmember. The transmission has a 4 degree slant on the mounting pad so I made a Aluminum block to fit between the mount and the transmission pad with the 4 degree angle milled in. The modified transmission mount was reinforced with 1/8 plate an added to the width for more mounting area.(As you can see in the picture the 4 degree difference the T56 has with the crossmember.)
