Added some angle braces (made from 2"X2" square tubing)to may transmission crossmember, boxed the ends of the member. Took some measurements and cut out the trans mount area of the crossmember. I,m waiting on another bellhousing as the quicktime won't work. The T56 Magnum has to bosses on the front that won't clear.
