believe me, it cant be shimmed.
I`ve fixed those types of problems before. Take it off and put some heat to it. I use a propane torch,when its hot enough it starts to smell and smoke,hold it in the correct position till COOL. May take several tries and may have to go past square and let it return after cooling. May need repainted when done tho,It MAY blister the gel-coat and or paint. I`ve fixed hoods,scoops,and even doors this way. Never had one go back later once its fixed.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
