I agree with Wise on using the older UD hyd profiles. The 108lsa with those lobes will give a noticable idle but power brakes "should" still function in a stroker combo,but you could spread them to 110 or even 112 if idle vac is a big deal.They run better than most would think(based on specs.LOL) I use them to replace other hyd grinds and they work great. Tim @ Bullet racing cams can get you the cam you need.
Not looking for noticable idle. I don't have power brakes or A/C. Just not looking for that attention and noise.
By grinding 110 or 112 on that ultradyne are you hurting it much? Or better start with something different.
So you want a stock idle,like a stock 318/360 truck engine? As far as spreading the lobes to 112lsa yes, it will tame the idle and even the 108 isn't exactly radical in a 408.
I've got the P4452761 .268°/272°, 228°/231° @.050, .450/.455, 110° cam in there now with 340. And I'm familar with a XE268 in a 340. I can tolerate a next step louder than those.
Are you saying a 416 stroker gobbles up some of that smaller centerline effect? I've heard that.
