Take a good look at the 60403 Lunati VooDoo cam .... if you want a little more, the 60404.
These cams are super good in street motors. They have a ton of low end thru to the redline. I have built several 408's for customers and they all seem to like shifting at 5800 (different cams in all of them including one with a solid roller) so keep that in mind. They will rev way past that but that seems to be a real happy point for the stroke.
How do you think the comp XE274H compares in there? Idle and power wise.
