Re: Brake Warning Light!
[Re: RM21N0A]
#838503
10/26/10 11:00 AM
10/26/10 11:00 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Not sure if this will be helpful, but a couple of months ago my brake warning light started staying on constantly, but not fully lit. Just sort of "half-bright". Came on bright when parking brake was on, like it should, but always stayed halfway lit when brake was off.
Brake system seemed fine, tried everything, no change, until I took the sending unit apart (pic attached), cleaned it, reinstalled, light started working properly again.
Thanks guys, I may have bumped the parking brake when I put the column back in If not then I will try the "swift kick method" and then rebuilding the sensor. Is it possible to get the sensor out w/ out getting fluid all over?
