I no longer have the modified pump cover and mount so I can't post any pics but Hemi Allstate's post should give you an idea..
let me change that..I do have the mount/isolator. I'll post a picture Sunday.
notice the bracket corner cut off. I also cut the rubber isolator off below the bracket. The gusset was removed but I welded a partial back in after I quit using the Milodon pump...also notice the thin isolator nut.
