I suggested to Steve at Milodon that he make a version of his oil pump for the World block. They could make a pump body that works with their gear set but doesn't have the external inlet. That kind of pump would still have the same volume as their existing pump but would be 3/4 of an inch shorter for more clearance and would be a dual inlet pump when used with their cover and the World block.
