i have a optima yellow (5yrs old) sears 2/10/50 battery charger that has two settings, conventional low maintenance and maintenance free deep cycle. i think the deep cycle setting charges the battery to a higher voltage which i assume could heat the battery more, should i not use the deep cycle setting?
