Yes, the fuselage Imperials really do weigh in excess of 5,000 lbs. Toss in 25 gallons of fuel and a 225 lb driver and it's well over 5,200 lbs.
I guess either the 3.73 or 3.91 gears will work. It will probably depend upon which I can find a speedo gear to match as well as the cost of the gears.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
