put spring on the trans jack under the lift and used ties
the above courtesy of a BG phone call
I think somebody else posted that around 2:15
Monte
true but BG called right after he posted this at 12.28.
Barnyard Bob
Reged: Mar 28 2006 Loc: Eighty Four, PA Re: NEED INFO ASSEMBLING COIL OVERS [Re: WILD BILL] #6224775 - Thu Sep 30 2010 12:28 PM Edit Reply Quote Quick Reply
Fred,are the springs the coorect length for the shock?I had a similar problem with a set that I was putting a 12" spring on and it was built for a 10" spring.Usually spin the adjusters all the way down and push the slotted top retainer in at an angle till it sits flush on the spring. Also try collasping the spring and use a couple of heavy wire ties to hold it and install the spriing and retainer that way.Be carefull and use substancial ties
then he whinned about it here so I made that post
- Thu Sep 30 2010 05:57 PM Edit Reply Quote Quick Reply
Glad you thought of that
Thanks Monte
home of the Sox and Martin Hemi Duster
