Might help to disconnect the shock.. Sometimes the shocks limit travel of the LCA & there is still tension on the bar... Are the anchors completely floppy loose? FWIW I've never used the tool you hammer on, I remove the LCA nut & use a prybar between the LCA & the K member to shove the LCA rearward, the wiggle the LCA forward & the bar pretty much falls out...
