resistance is all about cross-sectional area of the cable
Sort of correct but stranded cable has more surface area for the electrons to flow on - so it has benefits of being lighter, flexible and stronger and it will carry the same amp rating as solid piece of wire of the same gauge and material - that applies to pretty much to low voltage dc and ac circuits.
So what I was taught that in AC current flows on the surface of the conductor, and DC flows inside is wrong, or is there some threshold voltage regarding low voltage DC that I am unaware of? And the the more surface area for stranded is obvious, but not in agreement it applies here. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I'll leave the "stronger" by being stranded alone since it really isn't the key issue here.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
